Activity › Forums › Adobe Audition › Pitch change
Pitch change
Posted by Jpid-florida on January 25, 2006 at 2:01 pmFrequently after recording, the playback will be at a slower speed. Is this a problem with my PC or with Audition? Thanks.
Willie Toth replied 20 years, 8 months ago 3 Members · 5 Replies -
Willie Toth
January 25, 2006 at 2:46 pmWhat is your sample rate set to … What kind of system do you have? What version of Audition are you using? Is this in the multi track view or edit view … Does your mixdown play OK? WILLIE
Jpid-florida
January 25, 2006 at 2:50 pmI use 192 or 128. I’m almost certain that the PC is at fault and not Audition.
I have XP home OS, 1 gig ram.Jim
Willie Toth
January 25, 2006 at 5:14 pmJim,
I would use a 441K sample rate at 32 bit for recording … Micdowns of course should be 16 bit ……….. WILLIE
incidental poet
Michael Webb
January 26, 2006 at 6:02 pmi’m having a similar problem we record in 48k to use in prem pro. when we import it in it reports and plays back at 44.1
Michael Webb
Training / Support
Apple Certified Technician Digital Video / Xsan for Video
Microsearch, Houston Texas
713-988-2818
Michael Webb
Editor/Videographer
Post Squared
