Activity › Forums › Boris FX Particle Illusion › pI_Render fails to run
  • pI_Render fails to run
    Posted by Metaphilos on October 12, 2006 at 9:32 pm
    Someone described a similar problem but he never responded back if he had found a solution.
    I used pI_Render successfully for a long time and then did not use it for a few months and
    when I tried to use it, it just closes.
    My problem occurs when I open pI_Render and select AVI Options; the program closes. I have no problem with ParticleIllusion in rendering an avi.
    Has anyone experienced this problem and is aware of a solution.
    Thanks.
    Alan Lorence replied 19 years, 11 months ago 2 Members · 3 Replies
  • Metaphilos
    October 12, 2006 at 10:29 pm
    I just wanted to add to the previous message that I am able to use pI_Render to create an
    avi, if I do not select AVI Options. The avi that is created uses the Cinepak codec by
    default.
    Thanks.
  • Alan Lorence
    October 14, 2006 at 12:25 pm
    There seems to be some problem with pIRender in the AVI area. I just checked it myself (I don’t use pIRender very often), and I get an error message about the “H263 codec maximum size is ___ x____, please choose another codec”, but the AVI options still displays after that. Then, I notice that at least one of my codecs is not listed there.
    I thought that maybe the project that was loaded had a weird stage size which wasn’t compatible with some codecs, so I unchecked “autoload” and restarted pIRender so it loads with no settings, but it gave the same results.
    The only thing I can suggest is to render an image sequence with pIRender, then use another app to make it into a movie (if needed).
    Alan.
    wondertouch
  • Alan Lorence
    October 16, 2006 at 3:38 pm
    There’s a utility called “Sherlock – The Codec Detective” that you can download to see if any of your codecs are “broken”:
    https://www.free-codecs.com/download/Sherlock_The_Codec_Detective.htm
    That might help.
    Alan.
    wondertouch
