Activity Forums Adobe After Effects Pinning a shape to a wiggle line
  • Pinning a shape to a wiggle line
    Posted by Andrew Riss on August 10, 2021 at 4:41 pm
    This may be obvious but I’m not figuring it out…
    I want to “pin” a pin shape to a looping animated wavy line
    Graham Quince replied 5 years ago 3 Members · 4 Replies
  • Andrew Riss
    August 10, 2021 at 5:20 pm
    I am looking to create this kind of effect
    https://www.nasdaq50.com/stories
  • Kevin Camp
    August 10, 2021 at 11:10 pm
    Assuming the animated wavy line is footage, can you motion track it?
  • Andrew Riss
    August 19, 2021 at 10:09 pm
    it’s not, its a pre comp
  • Graham Quince
    August 21, 2021 at 10:50 am
    Take a look at the Create Null’s From Path script at the bottom of the window menu.
    Null’s follow points will generate null layers attached to the vertex points of your wavy line’s path. You can can parent your precomps to it. You’ll probably not want it in a pre-comp, or to at least copy the wave line path out of it.
