Activity Forums DaVinci Resolve Pink / magenta blinking
  • Pink / magenta blinking
    Posted by Stig Olsen on May 5, 2012 at 9:25 pm
    Im working on a commercial shot on Red Epic.
    Suddenly out of nowhere the clips on the timeline started blinking pink/magenta. I can see it when I play the clips, but also on the thumbnails. I have never experienced this before on any red footage.
    The color science is YRGB.
    When changing from lets say “redlogfilm” to something else, and back – everything is going back to normal.
    Any idea?
    Stig
    Stig Olsen replied 14 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Ola Haldor voll
    May 6, 2012 at 8:23 am
    For all it’s worth – what’s your hardware setup?
  • Stig Olsen
    May 6, 2012 at 5:07 pm
    The setup is the same as before, declink, a couple of graphic cards and a red rocket in the recommended slots.
    The only difference is that I did upgrade to Lion and the latest davinci patch with the latest drivers.
    Really noone that have experienced this magenta/pink blinking?
    Stig
  • Juan Salvo
    May 6, 2012 at 5:37 pm
    Nope, I haven’t seem this. What camera is this from? Whats the firmware. I’ve seen funky issues from certain camera firmware combos. Did you update the rocket firmware? Could be a rocket issue. I’ve seen them fail.
    Online Editor | Colorist | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Margus Voll
    May 6, 2012 at 5:43 pm
    simple way would be to remove rocket and see.
    my first guess would also be rocket.
    Margus
    https://iconstudios.eu
    DaVinci 8.2.1 OSX 10.7.3
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Jamie Franklin
    May 8, 2012 at 3:23 am
    Go into System Settings, Blackmagic Resolve driver, cycle on and off or turn off 444 and it should revert back.
  • Stig Olsen
    May 8, 2012 at 6:45 pm
    Thank you guys, I will try that.
  • Stig Olsen
    May 9, 2012 at 9:23 am
    Hi Jamie,
    I cant find a way to cycle on/off the black magic resolve driver and turn off 444, where to do that?
  • Jamie Franklin
    May 10, 2012 at 8:04 pm
    System *Preferences*, not settings, (sorry) window there should be a driver at the bottom “Blackmagic Design” with the yellow squares…
    If I cycle “Use 4:4:4 SDI on video” it usually gets rid of the 444 signal that gives you those colors.
  • Stig Olsen
    May 16, 2012 at 9:19 pm
    Thank you Jamie, now its gone!
