Activity › Forums › Boris FX › Pincushion in Boris? How to squeeze the middle, whilst keeping the sides stretched
  • Pincushion in Boris? How to squeeze the middle, whilst keeping the sides stretched
    Posted by Andrew Mehta on August 5, 2006 at 10:14 pm
    Hi, I have Boris FX6 with ICE’d FE.
    I want to change the shape of a piece of video, so that’s it’s like the following brackets:
    Only horizontal instead of vertical.
    Imagine like you’re looking at the cross-section of a curved ring, and viewing the video on the inside of the ring.
    How else to describe it?
    I could throw about words such as pincushion, or a widescreen that has been squeezed in the middle, and stretched at the edges.
    Obviously, I could just make a mask, but I don’t want the image behind it to stay flat.
    What filter should I be using?
    The closest I’ve got is “FE Bend it” but it only bends the top half upwards, it won’t bend the bottom half downwards at the same time. =P
    So it’s doing: )| when I want: )( albeit, horizontally, but I can’t type horizontal brackets, so you get what I mean. ^_^.
    I hope.
    Any advice welcomed.
    Andrew Mehta replied 20 years, 1 month ago 1 Member · 1 Reply
  • Andrew Mehta
    August 6, 2006 at 10:02 am
    Looks like the effect can be obtained by mapping the video to the inside of a cylinder, and making the front of the cylinder transparent ( opacity 0 ) so you can see through to the back of the cylinder, and then squash it, so it’s like a short ring, and you have your concave effect.
    Is amazing what a bit of sleep can do.
