Activity Forums Adobe After Effects Expressions Pin a text layer to the bottom of a scaled shape layer
  • Pin a text layer to the bottom of a scaled shape layer
    Posted by Joel Arvidsson on May 1, 2025 at 2:43 pm
    How can I pin a text layer to the bottom of a scaled shape layer without inheriting the scale?
    Hi!
    I have a shape layer (a vertical bar/rectangle) whose Y scale is driven by a JSON file, making it grow downward over time.
    Now I want to place a text layer at the bottom edge of the shape, so it moves downward in sync as the shape scales. But I don’t want the text itself to scale.
    The problem is:
    • Parenting the text to the shape layer (or to a null object attached to it) causes it to inherit the Y scale, which distorts the text.
    • Even if the null’s position is visually correct, its bounding box scales and so does the text.
    What I’m looking for:
    • A way to track the bottom Y position of the shape as it scales
    • Keep the text moving with it but not scaling
    Any expression based solutions or workarounds would be really appreciated!
    Roland R. kahlenberg replied 1 year, 3 months ago 4 Members · 5 Replies
  • Dan Ebberts
    May 1, 2025 at 3:45 pm
    You could try a scale expression like this, to counteract the scaling of the parent shape layer:
    s = parent.scale;
    [value[0]/s[0],value[1]/s[1]]*100
    You might need to move the text layer’s anchor point to the bottom of the shape layer to keep gap from changing size as the shape scales.
  • Joel Arvidsson
    May 1, 2025 at 4:53 pm
    Thanks Dan, I should try moving the anchor point to the botton instead of the shape layer. At the moment i pinned a null layer to the shape layer and connect to the null.
  • Dan Smith
    May 2, 2025 at 3:37 pm
    try this :https://aescripts.com/parental-controls/?srsltid=AfmBOoor8H9fbDm04lIYOrB4LyxLuW87UQfNMRL8_z6GuGhvy7jzn9w4
  • Joel Arvidsson
    May 5, 2025 at 9:08 am
    Thanks Dan, i have gotten it to work. I really appreciate it. I went back and tried to just do a simple animation with on the scale on the Transform of the layer instead of the shape layer group. Then I could get the text to follow the edge of the scale perfectly. Then i addaded in the json to drive the animation.
    I read some where that the scale was not as precise as the size on the shapel layer group. But i could not get it to work on there. Now it looks really good and I have built a scale aswell and got it to match perfect with the shape layer that grows downwards to illustrate diggig depth.
  • Roland R. kahlenberg
    May 8, 2025 at 3:57 am
    This Adobe Live video was supposed to provide a solution using the new Null Positional Feature but I can’t understand these two nor did I see all the new features. I could have missed something. Perhaps others may get more mileage –
    https://youtu.be/gyZWVkWKbgs
