Activity Forums Adobe After Effects Pin 3D layer to a specific point on CC Sphere
  • Pin 3D layer to a specific point on CC Sphere
    Posted by Nikolya Gousteau on May 19, 2012 at 7:03 am
    Hi all,
    I am trying to bind a 3D layer to a specific point on a sphere which is generated by CC Sphere. The layer should rotate together with the sphere as if it was pinned to it.
    To do this, I create auxiliary layer which is “frozen” into sphere, and hence rotates together with it. Then I create a target layer which will be pinned to the sphere, and move it in Z to the distance equal to the radius of the sphere. Finally, I pickwhip it to the auxiliary layer and voilà!
    However the target layer deviates from the surface of the sphere when the rotation is sufficiently big. Probably it is better to see the result , then describe it. The question is – why?
    I also attach the project file.
    4175_pointonsphere.aep.zip
    P.S. I know that it is probably easier to do this in true 3D app, but my goal is to understand AE better:)
    Nikolya Gousteau replied 14 years, 3 months ago 2 Members · 5 Replies
  • Stef Prein
    May 24, 2012 at 1:36 pm
    I have exactly the same question… Did it already work out?
    Stef Prein
    director/motion designer at StudioFets.
    Utrecht, The Netherlands
    http://www.studiofets.com
  • Nikolya Gousteau
    May 24, 2012 at 7:40 pm
    Unfortunately not yet:)
    Initially I thought that the perspective used by CC Sphere differs from the perspective used by AE… I tried to change the settings of camera, but it didn’t help.
    It is interesting that the rotation of the point on sphere appears to be tracked well this way. The only problem is distance from the point to the center of the sphere…
  • Stef Prein
    May 25, 2012 at 9:33 am
    I’m gonna post this question as well. Maybe someone picks it up this time 🙂
    Stef Prein
  • Stef Prein
    May 25, 2012 at 2:58 pm
    Solution!
    https://forums.creativecow.net/thread/2/1019053#1019053
    Good luck with your project!
    Stef Prein
  • Nikolya Gousteau
    May 26, 2012 at 4:08 pm
    It appears that I’ve just solved the problem 2)
    In the expression for Null position I wrote
    temp = thisComp.layer("CC Sphere Layer").effect("CC Sphere")("Offset");
    [temp[0], temp[1], 0]
    instead of
    [temp[0], temp[1], temp[1]]
    The question 1) remains.
