Activity › Forums › Boris FX Particle Illusion › Pillusion render AVI option
Posted by Mats Lundgren on October 12, 2007 at 1:02 pmHi, Thanks for the update, but when I click AVI options button in the render, windowsxp sais it has generated an error and need to close ?, what do I have to do ?
Mats Lundgren replied 18 years, 10 months ago 3 Members · 14 Replies -
Alan Lorence
October 12, 2007 at 1:08 pmCan you be more specific? I’m not sure if you mean in the update (3.0.2), in pIllusion, in pIRender, etc.
Alan.
Mats Lundgren
October 12, 2007 at 1:15 pmHi, i updated to 3.02, but then when I click the AVI option button in the standalone PillusionRender it sais it has generated an error and need to close, I have tried reset deafault settings to, but it is the same
Alan Lorence
October 12, 2007 at 1:22 pmOk, thanks. Try this and see if it crashes too:
1) run particleIllusion 3.0.2
2) ctrl-click the Save Output button. (This will force pIRender to be used for the render)
3) choose an AVI as outputWhen pIRender launches, it should open the codec selection dialog right away. If that works, select any codec and click the “render” button so pIR does the render and closes.
Now try running pIR alone and clicking the AVI Options button.
Alan.
Mats Lundgren
October 12, 2007 at 1:28 pmNo I did as you suggested, first the save as dialog comes up, I choosed to save it as an avi, then output options dialog comes up, and after that, the standalone render comes up, but it still sais it have generated an error and needs to close and want me to send the problem to microsoft
John Holste
October 12, 2007 at 1:36 pmWhen you run pIllusionRender what is in the box to the left of the AVI Options button? Also is it possible for you to save to a WMV output and click the WMV Options button?
Mats Lundgren
October 12, 2007 at 1:42 pmTo the left of the AVI option button in the field it sais “CineForm HD Encoder-2” I can
Alan Lorence
October 12, 2007 at 2:17 pmIf you render an AVI with pIllusion 3.0.2, you don’t have any problems, right?
Close pIRender.
If you’re familiar with Regedit, please run it and look at the following key:
HKEY_CURRENT_USER\Software\wondertouch\pIllusionRender\Settings\AviCompressor
Edit it, and set its value to “0”, then close Regedit.
If pIRender still crashes when you click the AVI Options button, delete the whole
HKEY_CURRENT_USER\Software\wondertouch\pIllusionRender key.Let me know what works.
Alan.
Mats Lundgren
October 12, 2007 at 2:46 pmIt works, :), but however seems to be the cineform encoder that makes the problem, Now I can choose avi codecs, but when I choose the cineform encoder it is the same, not much of a problem now, just have to see that I don
Alan Lorence
October 12, 2007 at 3:04 pmSo what was the solution? What did you have to do exactly in order to make it stop crashing?
The pin connection error messages usually indicate that you’re trying to render a resolution that the codec does not support. Some codecs only support specific sizes, while some codecs support any size.
Alan.
Mats Lundgren
October 12, 2007 at 3:16 pmThe solution was as you suggested :
“If you’re familiar with Regedit, please run it and look at the following key:
Edit it, and set its value to “0”, then close Regedit”
The value showed “3”, so I changed it as you suggested to “0”
restarted my computer and after that it worked perfectly, Thanks !
