Activity › Forums › Adobe After Effects › Pieces of 3D building disappear on export?
Posted by Charles Ferran on January 26, 2010 at 4:22 pmthe pics I’ve attached show what I’m talking about, in the first frame, the buildings base is intact, in the next frame, a piece of it disappears, it’s hard to see from the jpegs but watching it fly through, its glaring. I’m flying a camera down a road and going into this building. Other things do it subtly as well, like the sides of other buildings seem to flicker and overlap. They only do this on the export though, in After Effects it looks perfect… So what’s going on here? I know I’m bending After Effects to do something it really wasn’t designed to do, and I should expect some trouble, but is there a way to fix this, or fake it? the whole thing is fake 3D, I might as well fake a solution 🙂
Charles Ferran
845-699-5270
http://www.charlesferran.com“Far better is to dare mighty things, to win glorious triumphs, even though checkered by failure than to rank with the poor spirits who neither enjoy much, nor suffer much because they live in a gray twilight that knows no victory or defeat.”
Jurij Magoga replied 16 years, 3 months ago 4 Members · 13 Replies -
Charles Ferran
January 26, 2010 at 4:44 pmwell, I don’t know if its because I turned off OpenGL, but I now see that flicker in the jpegs, in my timeline, so that’s a step! (I guess?)
…AHA when I turn on Draft 3D the problem goes away, so what exactly is Draft 3D effecting? I’m assuming therein lies the problem…
Charles Ferran
845-699-5270
Charles Ferran
January 26, 2010 at 4:48 pmalso, the flickering building layers are fixed as well under Draft 3D…hmmm
Charles Ferran
845-699-5270
Charles Ferran
January 26, 2010 at 5:05 pmHere’s another example:
Draft 3D Off (BOO):
Draft 3D On (YAY):
Charles Ferran
845-699-5270
Charles Ferran
January 26, 2010 at 5:11 pmand, when I solo a building with Draft 3D off, the problem goes away with that building, but if I un solo it, problems back… I’m starting to think maybe my camera has something to do with it?
Charles Ferran
845-699-5270
Aled Rhys jones
January 26, 2010 at 5:16 pmHi Charles, I too have tried to push AE as far as it can go re 3D and had similar problems.
I think it’s something that Adobe haven’t seemed to fix for a long time. Here’s some considerations/fixes though:
If your layers contain alpha channels – make sure they don’t lie on the same plane as any other layer.
e.g. In photoshop you have your buildings bricks texture as one layer, windows on another layer above it; when this is brought in to AE – put the tiniest bit of space between them (perhaps 1-5 pixels in Z).
Switch off Motion Blur – I think this is the biggest culprit. Render out the movie and add a Motion Blur effect instead (I know it might not look quite how you’d like it; perhaps you can get away with switching off the MB for the bugged layers only?)
There are some other fixes I might know of – I’ll try to update this thread as and when they come to me.
Hope it helps.
Regards,
Aled
Aled Rhys Jones
VFX & GFX Senior Designer
wipgfx.com
Dublin, IrelandAfter Effects Consultancy | Motion Graphics | Compositing | Video Effects
Charles Ferran
January 26, 2010 at 5:26 pmHEY THANKS, I’M RENDERING, SORRY FOR CAPS 🙂 ANYWAY, I FOUND A KIND OF WORKAROUND, I LOWERED THE FOCUS DEPTH ON MY CAMERA, WHICH SEEMED TO FIX IT, WHEN ITS DONE RENDERING I’LL REPORT, IT WILL TAKE AWHILE, WORKING ON 2 GBS OF RAM O_O I REALLY NEED TO GET INTO CINEMA 4D, BUT I WOULD LOVE ANY MORE HINTS YOU MAY HAVE BECAUSE I’VE COMMITTED MYSELF TO ABOUT 3 MORE OF THE HEAVY 3D ANIMATIONS IN AFTER EFFECTS.
Charles Ferran
845-699-5270
Aled Rhys jones
January 26, 2010 at 6:00 pmNow – to anyone else (ahem… Adobe – you listening?!) here’s what I’m able to replicate which I’m pretty sure that Charles is having problems with:
and:
Am I right in suggesting these are the same problems Charles?
Aled Rhys Jones
wipgfx.com
Charles Ferran
January 26, 2010 at 6:09 pmlol, yes, the first one, I had that problem and fixed it, like you said, I had to move the layers off of each other, now the second one, my problem is similar, but goes away when I turn off certain FX, I’m going to try re-exporting with no motion blur like you suggested and see how that turns out…
Charles Ferran
845-699-5270
Charles Ferran
January 26, 2010 at 6:19 pmswitching off motion blur does nothing in the timeline, my motion blur was only affecting the road my camera was traveling down since AE won’t let me turn motion blur on for my building comps… I’m gonna render one out with now FX whatsoever and see what happens, here i go!!!
Charles Ferran
845-699-5270
Charles Ferran
January 26, 2010 at 9:03 pmjust an update for whoever is interested, still have the same problem, I was able to fake it by knocking down the focus on the camera to very low so you couldn’t see the problems because they were blurred out, BUT when I go to render I crash AE every time, so I think I am going to have to render out a version with no depth of field, then fake the depth of field on a video file version. But that’s a question for another day, for now, back to something a tad easier, moving words around 🙂 till next time…
Charles Ferran
845-699-5270
