Activity › Forums › Adobe After Effects › Pieces of 3D building disappear on export?
  • Walter Soyka
    January 26, 2010 at 10:31 pm
    Check out my recent post on how to render to image sequences — when your render fails, you can re-start it where it left off.
    Walter Soyka
  • Charles Ferran
    January 27, 2010 at 2:55 pm
    very good, thanks Walter, back into this today, I will be following your advice in that thread…
    Charles Ferran
    845-699-5270
    http://www.charlesferran.com
    “Far better is to dare mighty things, to win glorious triumphs, even though checkered by failure than to rank with the poor spirits who neither enjoy much, nor suffer much because they live in a gray twilight that knows no victory or defeat.”
  • Jurij Magoga
    June 10, 2010 at 7:04 pm
    I’ ve got the same problem building up a comp with 3d layers in Draft 3d.
    The workaround i’ve found is to export leaving Draft 3d enabled and full resolution, changing the render setting>quality from “best” to “current settings”.
    Another possible way (if you have enough ram) could be to RAM PREVIEW the whole comp, the go to COMPOSITION>Save Ram Preview.
Page 2 of 2
