Pictures with movement in 3D space break up as they move
I am relatively new to Motion, so I’m guessing this could be a pretty simple answer. I created a fairly simple Motion project that contains 4 pictures moving along a motion path within 3D space. The motion path is a closed circle that allows the pictures to move toward the camera and then away. They are moving at a steady rate of speed. When I bring the Motion project into FCP, I notice that the pictures are breaking up a little bit. I appears like there are scan lines that move down the picture. I tried De-Interlacing the Motion project after I brought it into FCP, but that didn’t help much. Are there any settings I am missing? Any other filters I should try using?
