Activity Forums VEGAS Pro Pictures and Video change color when burning to Blu-Ray
  • Pictures and Video change color when burning to Blu-Ray
    Posted by David Bagatelle on August 10, 2012 at 1:13 am
    I have photos and video that look great on my computer, but when I burn to blu-ray they look shiny, or the colors are off. It’s not horrible.. but not WYSIWYG.
    Is there an easy way to improve the quality of output when burning to Blu-Ray? As that is the medium I will be showing off the video.
    Dave
    David Bagatelle replied 14 years ago 3 Members · 3 Replies
  • Michael Acres
    August 10, 2012 at 1:42 am
    adjust the setting on your TV
  • Dave Haynie
    August 11, 2012 at 3:34 pm
    Photos shown on uncalibrated monitors are not going to be graded correctly. If you’re not doing any color adjustments, you may just be lucky that your PC monitor is faithful to what you expect to see, or maybe it’s showing you total fiction. Can’t really tell without color calibration. About all you know is that your monitor and your TV are different. And unless you have a CRT or LCD IPS or PVA/MVA monitor, there’s no special reason to expect your monitor to be the correct one here.
    The best calibration is with a calibration tool. I use a fairly cheap one called a Huey Pro, from Pantone, which is probably out of production. Anything’s better than nothing. But without this, you can get a decent calibration if you have a color-aware application (like Photoshop) and a color profiled printer, like pretty much any Epson. Print a test pattern, a photo, etc. and compare to the colors on your monitor. Adjust accordingly.
    Now take those same photos and test patterns to your TV. Adjust accordingly.
    Also, check your DVD collection for any DVD with the “THX” logo on it (or see here: https://www.thx.com/home/dvd/search.html). THX DVDs include a short color calibration segment (“The THX Optimizer”) that will offer a very specific series of images to help you set dark levels (adjust brightness), light levels (adjust contrast), and color properly. You can run this on your PC, too.
    -Dave
  • David Bagatelle
    August 13, 2012 at 12:42 am
    simple answer.. but effective. that worked.
