picture jumps during the horizontal pan
Hi everybody,
I would be very happy if anyone can share their thoughts about the following problem I am having:
I am making a quicktime movie that will be for web use (mainly streaming but also downloadable).
The movie has parts where I have a camera that pans horizontally and shows still images of objects. Imagine a horizontal movement in a museum.The problem is that, even though I don’t see any jumps in the after effects RAM preview, I always see some after I render the composition. Plus, even though they look like they happen on the same spot every time i play, I guess they are not, cause if I go to the jump and play it from there, then the jumps happen slightly later. This tells me that the problem is coming from compression?
I think it may also be caused by the sped of the movement, but i am trying not to change that, instead I am in search of a good compression that can solve it.
So far I’ve been experimenting with h264. My composition is 30fps, I also tried to bring it up to 60fps, the general motion got a lot smoother but I am still seeing jumps.
Any help would be greatly appreciated.
Thanks in advance!
Sonja
