Activity Forums Avid Media Composer Picture controlled wipe effect
  • Picture controlled wipe effect
    Posted by Jennifer on July 22, 2005 at 2:59 pm
    Hi Everyone,
    I am trying to make a custom wipe using the gray-scale values of a picture to control the wipe.
    Example: In Photoshop, I created a gray-scale image (a word in black that fuzzes through gray to white at the edges and corners of the picture). I then applied a luma key to the video (in V2) that I wanted to key over. I am having problems trying to get the luma key to use the picture as its wipe controller.
    I feel that there has to be a way to do it but everything I have tried doesn’t work.
    Jennifer
    Struggling AVID Editor
    Charley King replied 21 years, 2 months ago 2 Members · 4 Replies
  • Charley King
    July 22, 2005 at 5:34 pm
    Not working for me either, have to think about why it isn;t working. I know what you are attempting, but not sure the method is right for it.
    Charlie
  • Jennifer
    July 22, 2005 at 7:25 pm
    Specifically, I put the luma key on the video in V2. Then, stepping into that effect, I put the grayscale image into the layer below.
    Then I applied the BCC Make Alpha effect to the grayscale image and set the output to a gel.
    I thought that the resulting crisp image would make it easier for the luma key to work. (The gel output sends out a black and white image with a gray haze only where the change was occuring. This black and white image changed over time.)
    It kinda worked but during the duration of the effect, there was either a black or white
  • Jennifer
    July 22, 2005 at 8:48 pm
    Ok, I got it to work but it seems very clumsy. I had to use 3 video tracks:
    V3-foreground video
    V2-grayscale image to control the key
    V1-background video
    On V3 I put the
  • Charley King
    July 22, 2005 at 9:42 pm
    [Jennifer] “On V3 I put the
