Activity Forums Adobe After Effects Expressions Pickwhip one layer’s Y position to another’s Y position, each layer with its own respective range
  • Pickwhip one layer’s Y position to another’s Y position, each layer with its own respective range
    Posted by Tommy Dimmel on January 21, 2015 at 1:05 pm
    I am wanting to pickwhip the y axis of ‘Layer A’ with the y axis ‘Layer B’. I want the ‘Layer A”s Y-Axis, when adjusted between 0-100, to adjust ‘Layer B”s Y-Axis to a range of 25-75 at the same time. Can someone please help?
    Thank you!
    Tommy Dimmel replied 11 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 21, 2015 at 3:02 pm
    The expression to do that would look like this:
    yA = thisComp.layer(“Layer A”).position[1];
    yB = linear(yA,0,100,25,75);
    [value[0],yB]
    or, like this if you have dimensions separated:
    y = thisComp.layer(“Layer A”).transform.yPosition;
    linear(y,0,100,25,75)
    Dan
  • Tommy Dimmel
    January 22, 2015 at 8:23 am
    Dan,
    Thank you so much for this! Worked perfectly and you expanded my knowledge of expressions! Really appreciate it!
