Activity Forums Adobe After Effects Expressions Pick Whip it good!
  • Pick Whip it good!
    Posted by Ocean Byrne on April 3, 2012 at 3:52 pm
    Is there a way to pick whip every channel on a layer, or in an effect?
    Specifically I have 2 layers which both have Trapcode Particular effects on them, and i want them to behave the same, except for 2 parameters. Particular has like 50 channels, fun as the pickwhip is, I dont really want to have to individually tie every one of them.
    Would be nice if I could say, everything follow this layer, except you and you.
    Paul Roper replied 14 years, 5 months ago 2 Members · 1 Reply
  • Paul Roper
    April 3, 2012 at 4:17 pm
    This script:
    https://aescripts.com/ft-effect-instance/
    will create an “instance” of an effect (a copy of the same effect, with all parameters ‘pick whipped’ to the first). You can easily then go in and edit (delete the expression) for the few parameters you wish to manually edit.
