Activity Forums Adobe After Effects pic: depth of field adding grain to flat images
  • Tristan Nieto
    July 17, 2009 at 12:30 pm
    Short answer is no. Grain artefacts usually happen in AE when blur settings are too high. It happens a lot with the Radial Blur effect too.
    You can try taking the project settings up to 16-bit colour (or 32) and that might help, or try dialing down the Blur Amount.
    If you’ve got the time, there’s always the Remove Grain effect, or you can simulate DoF using gaussian blurs with expressions linked to distance from camera and what not, but it’s more trouble than it’s worth.
    Tristan Nieto
    Visual Effects & Motion Graphics
    tristannieto.blogspot.com
  • Jason W. miltt
    July 17, 2009 at 2:25 pm
    thanks. I ended up doing it by hand applying fast blur to the layers i wanted.
