Activity Forums Boris FX Particle Illusion PI3 Emitter Library folder do not display new downloads
  • PI3 Emitter Library folder do not display new downloads
    Posted by Ann Ari on August 8, 2009 at 1:28 pm
    Hi, I have noticed since I have updated PI3 in the Program folder of Emitter Library I can not see the downloaded library such as emitters_09_06.il3,emitters_09_07.il3, and old _user_ best.il3. But from PI3 software when I access library I can locate above three files.
    The only reason I want to see these files in program/emitter library is because I wanted to drag two 2009 updates in the folder of 2009 which I have assigned. However, I have manually copied the two libraries.
    But I still want to know why I can not see two libraries as mentioned above in the Emitter library folder.
    And how can I download old _user_ best.il3
    Your reply in this regard will be appreciated.
    Thank you
    *** I wonder if you ***
    Ann Ari replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
