Activity › Forums › Boris FX Particle Illusion › PI malfunction
PI malfunction
Posted by Paul Hansen on April 23, 2007 at 5:45 pmFor no reason I can detect, the quick load library function no longer works. Quick load library shows with the little right hand arrow pointing right but… no libraries.
Paul Hansen replied 19 years, 5 months ago 2 Members · 4 Replies -
Alan Lorence
April 23, 2007 at 10:40 pmDid your “Emitter Libraries” folder get renamed? Did all of the files in it get deleted?
Alan.
Paul Hansen
April 25, 2007 at 1:36 amI moved the library to a different drive but kept the name “Emitters Library”. When I do, “Load Library…” The program has no problem finding all the libraries and I can load them from there but not from “Quick load library”
Alan Lorence
April 25, 2007 at 12:02 pmThe Emitter Libraries folder must be in the same folder that the particleIllusion exe is.
Alan.
Paul Hansen
April 25, 2007 at 6:24 pmThanks, Alan… I guess I will just use the “Load Library” function then… my C drive is pretty filled up!
