Activity Forums Boris FX Particle Illusion PI For AE version 1.04 not installing in CS6
  • PI For AE version 1.04 not installing in CS6
    Posted by Mike Schmitt on January 19, 2013 at 7:39 pm
    Hi there, I’m moving over to a SSD on my Mac. OS X mountain Lion, Adobe CS6.
    I try to install PI for AE version 1.04 (which says it is CS6 compatible). In fact I know it is because it still works on my old hard drive.
    It installs but only seems to go to CS4 and CS5. Anyone know how to make PI see CS6 and install there?
    A million other things to do. Moving on to another plug in suite.
    MIKE
    Mike Schmitt replied 13 years, 7 months ago 4 Members · 4 Replies
  • Peter Kovacs
    January 20, 2013 at 1:32 am
    Mine worked fine (1.04) and it detected CS6.
    Check to see if CS6 is installed into this specific folder:
    C:Program FilesAdobeAdobe After Effects CS6
    When I finished installing particleillusion, it went into this folder:
    C:Program FilesAdobeAdobe After Effects CS6Support FilesPlug-inswondertouch
    -Pete
  • Alan Lorence
    January 21, 2013 at 3:31 pm
    After install there is a “plug-in copy” subfolder in the particleIllusion Application folder. You can copy the file there into the correct “plug-ins” folder for CS6 for a “manual install” if needed.
    I’m wondering why it would fail to detect though. Do you have CS6 installed in some strange location? Did you install CS6 normally, using the AE installer?
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • David Jolosky
    February 4, 2013 at 5:46 am
    Hi Alan
    can you confirm that PI for AE is actually CS6 compatible. Great if it is. New licenses available for purchase?
    david jolosky, visual communications || design || construct || interact
  • Mike Schmitt
    February 4, 2013 at 6:54 am
    Yes, it’s compatible. I have successfully installed it. I was doing the licensing wrong.
    thank you for responding.
    MIKE
