Activity Forums Maxon Cinema 4D physical render or vray or switch to learn maya for real world photo realistic render
  • physical render or vray or switch to learn maya for real world photo realistic render
    Posted by Nizaryos Nassour on December 10, 2013 at 8:53 am
    hello all my name is nizaryos new to this forum
    i am using cinema 4d for about 2 years now for motion graphic in a television industry now i am trying to replicate real world lighting texture shadow …….
    i just got vray for c4d r14 for rendering real world such as characters tanks buildings sea nature …..
    but i cant achieve desired results should i switch and learn maya for real world
    here is my render with physical
    here is my render with vray
    Nizaryos Nassour replied 12 years, 9 months ago 5 Members · 13 Replies
  • 13 Replies
  • Andy Henik
    December 10, 2013 at 11:22 am
    Hi there,
    Can you share a simple file with both settings?
    I’m sure it is all about setting it up right.
    There really is no difference for you using C4D/3dMax/Maya or so.
    At the end its all about the right settings.
    Kind Regards
    Andy
  • Nizaryos Nassour
    December 10, 2013 at 2:03 pm
    thanks andy for your response i am uploading vray render and physical render
  • Nizaryos Nassour
    December 10, 2013 at 2:11 pm
    did you receive the files
  • Andy Henik
    December 10, 2013 at 4:14 pm
    No I did not. Did you upload them under your post? I can’t find them!
    Sorry, please try to upload them again. I’m not sure if it is allowed to give you my personal email address, or else I would give it to you.
    Thanks Andy
  • Brian Jones
    December 10, 2013 at 4:22 pm
    if you click on his name it takes you to files that were uploaded (useful for when someone doesn’t copy-paste the links).
  • Andy Henik
    December 10, 2013 at 6:40 pm
    Thank you I got them.
  • Adam Trachtenberg
    December 10, 2013 at 11:03 pm
    Instead of switching applications you’d be much better off putting some time in learning one or two of the render engines available for Cinema. That way you’ll just have to learn a render engine instead of having to learn a new render engine AND a whole new 3D application (and Maya is not so user friendly as Cinema).
    With Cinema you can use vRay, Mental Ray (Maya’s render engine), Octane, Oxygen, Maxwell, and a number of other render engines, in addition to the standard and physical renderers. Many Maya users doing photorealistic work rely on vRay.
  • Andy Henik
    December 10, 2013 at 11:52 pm
    I sent you a file back to you for download. For now just the physical render.
    Tomorrow I will try to find the vRay solution.
    Hope I helped a little.
    Thanx
    Andy
  • Nizaryos Nassour
    December 11, 2013 at 11:04 am
    thanks for the reply i think it is going to take time to get used to realistic render engine
  • Nizaryos Nassour
    December 11, 2013 at 11:10 am
    thanks man you are a life saver the results are great especially the depth of field also one of my friend told me to add volume metric light and ray light beam should be visible and particle dust atmosphere in after effect to add more realism environment should this work in addition of your render settings???
