Activity Forums Adobe Premiere Pro Photoshopped layer ‘drops’ in Premiere with effects applied
  • Photoshopped layer ‘drops’ in Premiere with effects applied
    Posted by Jamie Hancock on October 28, 2010 at 8:41 am
    Morning (or whatever it is where you are)
    I’ve taken the advice of a couple of people here when trying to add depth to still images in Premiere. It’s working really well, but there is a slight issue. I’ve opened the still images in Photoshop and created new layers (via Copy) of each of the main items in the photographs and saved as a PSD. I’ve then imported the separate layers into Premiere and have been adding gaussian blur to create a depth of field effect as I pan across the still.
    The issue is that with one of the layers, when it arrives at the keyframe to remove the blur, the layer drops in the frame slightly, only a pixel or two, but it is very noticeable on playback. I’ve checked my motion effects and there is no movement applied there other than a pan. I’m racking my brains to think what it could be that is causing this, and how to fix it. Does anyone have any ideas, please?
    Cheers,
    J…
    Jamie Hancock replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
