Activity › Forums › Apple Final Cut Pro Legacy › photoshop with final cut
Posted by Tracy on March 16, 2006 at 2:17 pmdoes anyone know if I can import a layered photoshop file in FCP 4.5? Right now it is just coming in as a flat image.
Tracy replied 20 years, 6 months ago 4 Members · 4 Replies -
Wayne Carey
March 16, 2006 at 2:26 pmIt should…. It always did for me. I find it a pain sometimes and it seems like FCP doesn’t handle Photoshop PSDs very well at all. I get aliased edges and distortion problems with mine, but then again I am using Photoshop 7.0, not CS2.
When you import the file, it comes in as a sequence, of sorts…. meaning that if you double click it, it will open a sequence with all of your layers.
_____________________________
Wayne Carey
wcarey@strikeking.com -
Jerry Hofmann
March 16, 2006 at 2:28 pmIf you flatten the file in Photoshop, it will lose it’s layers, but if you don’t it shouldn’t. Needs to be a non flattened file, and contain NO blank layers.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Tom Wolsky
March 16, 2006 at 2:29 pmWas the file created on a PC? It has to be saved in the Mac version. It also has to be 8-bit RGB.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
Tracy
March 16, 2006 at 2:43 pmit was made on a PC..I just had to go in and resave all the files for Mac… It is working now. Thanks for all your help.
Tracy
