Activity Forums Adobe Encore DVD Photoshop to Premier to Encore
  • Photoshop to Premier to Encore
    Posted by Keith Southern on September 20, 2011 at 1:23 pm
    I’m making the switch over from FCP/Studio Pro to a full Adobe workflow and so far everything has been going well. I’ve noticed this small problem and was wondering if it’s a known bug or if there’s something I’m missing. It seems to relate specifically to Encore.
    In Photoshop, I create document ‘A’ using predefined setting:
    PAL D1/DV Widescreen 720 x 576
    PAR D1/DV PAL Widescreen 1.46
    Using a screen ruler this measures out at 1050, which I understand the reasons for and is fine.
    In Premier I create a sequence with settings:
    720 x 576 16:9
    D1/DV PAL Widescreen 16:9 1.46
    Import document ‘A’ and drop into sequence. Everything is fine, still measures to 1050.
    Dynamic Link this Premier sequence to Encore.
    Video timeline looks fine – still measure out at 1050
    At this point I want to import document A to use in the menus.
    Create new menu – measures 1050 – ok.
    Import document A and drop into new menu – it appears as 1024, not 1050.
    If I instead choose to ‘edit menu in Photoshop’ from Encore, I can then paste in document A as a background, save and that will then display correctly in Encore.
    Is this a bug? Why does not encore not correctly interpret document A?
    Apologies if this has been brought up, I tried searching but mostly found discussions on par, which isn’t entirely the issue.
    Thanks.
    Keith Southern replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
