Activity Forums Adobe Illustrator Photoshop to Illustrator
  • Photoshop to Illustrator
    Posted by Reggie Spires on July 11, 2009 at 3:11 pm
    Best File format coming OUT of Photoshop to due a live trace in Illustrator when the Photoshop Image is on a transparent Background.
    Reggie
    ps End result is Zaxsworks invig pro inside of AE
    Herm Medina replied 17 years, 2 months ago 4 Members · 3 Replies
  • Vincent Rosati
    July 11, 2009 at 5:35 pm
    I like TIF/LZW
    Vince
  • Les Nemeth
    July 13, 2009 at 5:44 pm
    It really doesn’t matter. If you want the best result, you will always end up needing to trace using the pen tool. Otherwise you will only get an amateurish end result no matter how you slice it.
  • Herm Medina
    July 15, 2009 at 2:36 pm
    I typically use PNG; the format is very clean with respect to hard edges unlike JPEG and is usaully quite small (byte-wise). Hope this helps!
