Activity › Forums › Apple Final Cut Pro Legacy › Photoshop Text Shifts when using a Transition
  • Photoshop Text Shifts when using a Transition
    Posted by Sam on November 22, 2006 at 3:50 pm
    Howdy Guys
    Weird, Dropped a layer PS file with Text layers. Applied a Blur effect to the layer. When the effect is complete (2 seconds long), the text layer shifts down by few pixels enough to notice the jump. Any ideas? When effects are applied to PS layers any special tricks?
    I am using a simple 8bit DV50 Preset with Kona
    Sammy
    Sam replied 19 years, 10 months ago 3 Members · 3 Replies
  • Tom Wolsky
    November 22, 2006 at 4:06 pm
    Are you looking at the rendered output on a video monitor?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Neil Ryan
    November 22, 2006 at 10:11 pm
    “…the text layer shifts down by few pixels enough to notice the jump”
    A one pixel shift is enough to be visible.
    “When the effect is complete (2 seconds long) …”
    Have had similar issues myself; one workaround – if you can work this into your situation – is to have the filter active for the entire clip.
    When you want it ‘off’ give it its minimum value, but greater than 0.
    For example, if you have keyframe a blur off over time, from say 25 to 0, make the ‘0’ value 0.1 instead.
    hope that leads you to a solution.
    cheers.
  • Sam
    November 23, 2006 at 3:11 am
    Thanks for the tips guys. Tom, I was looking at the render output. PostMan, your tip did the trick.
    Sammy
