Activity Forums Adobe Photoshop Photoshop really slow in opening files
  • Photoshop really slow in opening files
    Posted by Dalanm on July 12, 2005 at 10:59 pm
    Hi all,
    I’m new to this forum and am having problems opening files with Photoshop. I’m trying to open, nothing else, a psd that’s 139.6 MB, not too big. The problem is that Photoshop is taking forever just to open the file. What should I do to remedy this? After the file has finally opened, everything takes a long time to perform. Even if the help is just instructing me how to search for the help via previous posts, then that’s fine. I’m working on a Dual 1 GHz PowerPC G4, 1 MB L3 cache, OS Version 10.4, and 1.5 GB DDR SDRAM. Thank you for your time.
    Dalan
    Rufus Napkin replied 21 years, 2 months ago 3 Members · 2 Replies
  • Mike Gondek
    July 14, 2005 at 7:57 pm
    There are many things that can casue this such as opening the file. SOme common fixes are
    purge your cache
    copy the file to your hard drive
    run norton disk doctor or some disk utility
    check that your ram is proerly installed
    make sure your drive has plenty of free hard drive space
    close unnecessary fonts
    close all other open applications
    create a new user in OSX and log in as that, then try to open the file
  • Rufus Napkin
    July 16, 2005 at 1:03 am
    I had a similar problem (I am assuming you’re referring to CS2 – otherwise it doesn’t apply). I upgraded the hard drive to big, fast and mostly empty, and video card to at leat 128MB.
