Activity Forums Adobe Photoshop Photoshop realistic shadow
  • Photoshop realistic shadow
    Posted by Seth Taylor on August 30, 2005 at 11:12 pm
    Point 1:
    I’m trying to produce a realistic shadow.
    Point 2:
    I would like the shadow to have harder edges the closer it is to the object.
    Methods Tried:
    -I’ve tried making two 50% grey layers with different gaussian blurs applied to them with layer masks used to smoothly transistion between the two layers, but it still doesn’t look right.
    -I’ve also tried using brushes with varying widths and hardnesses
    Are there methods you have liked that you could share? Any help is appreciated.
    Jim Kanter replied 21 years ago 2 Members · 2 Replies
  • Seth Taylor
    September 1, 2005 at 10:34 pm
    For those interested:
    I’ve been experimenting with a linear black to white gradient in an alpha channel and applying that channel in an lens blur. So far it will only blur the interior of a clipped object. My next task is to see how to blur the edges of a clipped object.
  • Jim Kanter
    September 2, 2005 at 9:28 pm
    1. Try using blur brushes of varying sizes and flows.
    2. Use gradient selections to apply blurs. (Put a gradient in a channel and load the channel as a selection.)
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
