Activity › Forums › Adobe After Effects › Photoshop Plugins in AE CS4
  • Photoshop Plugins in AE CS4
    Posted by Lou Borella on January 5, 2010 at 3:20 am
    I’m trying to use the Photoshop plugin “Color Halftone” in AE CS4.
    I’ve tried moving the PS plugs to both the AE plugins folder and then the MediaCore folder in the main Library but AE doesn’t see the filters.
    Did Adobe break this? I know we used to be able to use PS filters before.
    Petes Halftone filter doesn’t work anymore either.
    Any thoughts?
    Lou …
    Todd Kopriva replied 16 years, 9 months ago 2 Members · 1 Reply
  • Todd Kopriva
    January 5, 2010 at 3:27 am
    Using Photoshop filters directly as plug-ins in After Effects hasn’t worked in a very long time.
    You can process frames in a batch in Photoshop and then import the image sequence back into After Effects.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
