Activity Forums Adobe After Effects Photoshop pixel for 720 pixel DVD
  • Photoshop pixel for 720 pixel DVD
    Posted by Laura Harvey on January 25, 2010 at 8:43 pm
    I created Photoshop 720×480 as I selected under Film & Video. It is for FCP but letters show pixels on HDTV. My DVD project is 16:9 and it is not HD. Any suggestions?
    Laura Harvey replied 16 years, 7 months ago 2 Members · 2 Replies
  • Paolo Ciccone
    January 25, 2010 at 10:15 pm
    If you create a video at 720×480 and the watch it on a HDTV it will always look crappy unless you disable the upscaling. HDTV, depending on the model, is either 1280×720 or 1920×1080. On a 720p you have 921,600 pixel per frame, on 1080 you have 2,073,600. Your PS image has 345,600 pixels. There is a ratio of 2.7 times magnification for 720p and more than 4 times for 1080p. Upscaling always gives you pixelation. If you enlarge your image in Photoshop 3 or 4 times you will get the same result.
    That’s the reason why all SD shows look worse on HD TV than on a conventional TV.
    Paolo Ciccone
    Pret-A-3D
    https://www.preta3d.com
    https://www.paolociccone.com
  • Laura Harvey
    January 25, 2010 at 11:48 pm
    Dave LaRonde: If the project is destined for 16×9 DVD, why are you even bothering to look at it in HD?
    Because I viewed DVD on HDTV. That’s why font text look pixeled.
    Next person said that it will be always be pixeled on HDTV if using SD 16:9 DVD.
    So basically I stuck with it. Just wonder if I can create DVD SP as HD DVD and use SD 16:9 video and using photoshop jpeg as HDTV.
    Will that work?
