Activity Forums Apple Final Cut Pro Legacy Photoshop Layers
  • Photoshop Layers
    Posted by Chris Babbitt on April 3, 2007 at 3:37 am
    A client sent me a Photoshop file which I opened and all the layers showed up in the Layers palate. But, when I bring it into Final Cut it doesn’t import with the layers. It just shows up as a standard graphic file, not the usual sequence icon. I even tried re-saving it in Photoshop, but, no luck> Any thoughts?
    Arnie Schlissel replied 19 years, 5 months ago 2 Members · 3 Replies
  • Arnie Schlissel
    April 3, 2007 at 4:10 am
    Check to see if the file has a separate alpha channel. If it does, delete the alpha & then try to import the .psd into FCP.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Chris Babbitt
    April 3, 2007 at 3:50 pm
    Thanks Arnie. There was no separate Alpha Channel, but each layer did have an effect applied to the text. I remembered something about this affecting layers in FCP, so I turned off the effects, and the layers returned in FCP. I also added a transparent layer at the bottom. I seem to recall that in order to use effects, you need to add a transparent layer under each existing layer in order for the effects to show up in FCP. Correct?
  • Arnie Schlissel
    April 3, 2007 at 5:18 pm
    To use the layer effects, you need to ‘flatten’ each effected layer by merging it with an empty layer below it.
    Arnie
