Activity › Forums › Apple Motion › Photoshop Layers Out of Alignment
  • Photoshop Layers Out of Alignment
    Posted by Brent Streeper on August 27, 2010 at 7:56 pm
    I’ve got a Photoshop file that I need to animate in Motion. The psd file is RGB 8bit and has 2 layers.
    When I bring the psd file into Motion, the top layer is scaled way up and has different x,y position coordinates than the bottom layer. I can almost get the top layer to line up with the bottom, but it’s still slightly off.
    Any thoughts on how to import the psd into Motion so that the layers line up correctly?
    Brent
    Motion 4.0.1
    Photoshop CS
    Brent Streeper replied 16 years, 1 month ago 3 Members · 3 Replies
  • Mark Spencer
    August 27, 2010 at 8:51 pm
    Make sure your Motion project file has the same pixel dimensions as the Photoshop file.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Zak Peric
    August 27, 2010 at 9:01 pm
    you can check this in Apple Motion by going to edit project properties. I hope this helps…
  • Brent Streeper
    August 27, 2010 at 9:54 pm
    Thanks for the response!
    The psd file is larger than the 4096 pixel limit. It’s a scan of a dollar bill that I want to get super close in on, and then pull back to reveal the full bill. Is there a way around the size limit?
