Activity › Forums › Adobe Photoshop › photoshop layers not acting normal
  • photoshop layers not acting normal
    Posted by Glen Jennings on September 1, 2005 at 11:12 pm
    Hi, I am using photoshop 7.0 on this computer for the first time, its the same version that i use at work all the time but some things are not acting right here and i can’t figure it out!
    Well what i am doing is pasting a copied image from a .tif into an empty document that i created and it pastes it into the BACKGROUND which is LOCKED. And it won’t let me create a new layer, infact all of my layer menu options are turned off and i can’t seem to get them to work. I can’t unlock the backgound layer either amd every time i paste a new copied image from the .tif it will paste it into the background layer instead of creating a new one.
    Why is it doing this and what setting do i have to change to turn it off?
    If anybody knows how to fix this issue please help!
    Richard Harrington replied 21 years, 1 month ago 2 Members · 1 Reply
  • Richard Harrington
    September 2, 2005 at 4:04 am
    Sae as before.. you are working in 16 bit… change image mode to 8 bit
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
