Activity › Forums › Adobe After Effects › photoshop layers always default to dv/pal aspect ratio
Posted by Nomis on August 9, 2005 at 3:53 amHi there cow people!
Can anyone help me. When i import photoshop files into ae, they default to dv pal aspect ratio. I then have to go and interperat footage to every layer and change to square px. How can i change this?
Thanks in advance.
John Dickinson replied 21 years, 1 month ago 2 Members · 5 Replies -
John Dickinson
August 9, 2005 at 4:12 amAre you importing them at 720 x 576 resolution? If so then After Effects is mistaking them for D1/DV PAL footage and interpreting them accordingly. Try making your Photoshop files 768 x 576 and AE will interpret them as square pixels. If you have Photoshop 7 or later you can create your file at 720 x 576 but remember to use the D1/DV PAL pixel aspect ratio setting in Photoshop.
JD
John Dickinson
Motionworks
https://www.motionworks.com.au -
Nomis
August 9, 2005 at 4:32 amThanks JD,
Are you saying that i should make my files 720 x 576 with dv/pal aspect ratio in photoshop, and ae will interprate them as square pixels?
Sorry for soundind stupid. I need to supply my ae files to my client and they are requesting comps that are 720 x 576 with square pixels. So im just trying to work out the easiest way of doing this.
Any further help would be greatly appriciated.
cheers.
John Dickinson
August 9, 2005 at 5:40 amNo I’m saying that AE will interpret them as non square pixels. Or if you make your file at 768 x 576 AE will interpret them as square pixels. If the client is asking for 720 x 576 square pixels you’ll need to force the interpretation of the footage by doing it manually. You must make sure that your comp is created at 720 x 576 square or else your photoshop file will be too short on the left and right edges.
JD
John Dickinson
Motionworks
John Dickinson
August 9, 2005 at 6:03 amIgnore the second paragraph of my last post. If the client wants the files in 720 x 576 square pixels, even if you make your photoshop files and your comp using those specs the vision will look stretched in a video monitor. You should double check with the client. You may also like to do a test where you create a perfect circle in Photoshop (720 x 576), import that into AE and interpret it as Square pixels, then drop it into a 720 x 576 square pixel comp. It will look okay on your PC but stretched horizontally on your video monitor. If you change the comp to non square pixels, the circle will look slightly squashed on your PC but fine on the video monitor. You’ll also notice that the file is now too short on the left and right sides. If you work at 768 square or 720 non square in Photoshop you won’t have this problem. This area can be a little confusing but I hope that helps.
JD
John Dickinson
Motionworks
John Dickinson
August 9, 2005 at 6:14 amYou may find this of use:
https://www.adobe.com/support/techdocs/322300.html
JD
John Dickinson
Motionworks
