Activity › Forums › Adobe Photoshop › Photoshop is frustrating me… help?
  • Photoshop is frustrating me… help?
    Posted by Craig L. on July 13, 2005 at 4:41 pm
    Ok, now I do have an ancient version (version 6) so don’t get mad at me. This is something I have NEVER been able to figure out and have just been working around it for some time. Simple: CUT AND PASTE! Why is it that most of my layers always have the “CUT” command grayed out?!?! Why can’t I just “CUT” a layer/item?
    I have opened a .JPG and dragged it into my current project. I select it, go to the edit menu and cut and copy are all grayed out.
    Then I created a shape using the shape tool and I wanted to paste it into another shape. Clicked edit and once again, cut and copy are grayed out.
    Any ideas here?
    Judge S.
    David Johnson replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jeff Kelley
    July 13, 2005 at 10:03 pm
    You have to make a selection using the marquee tool. If you just select a layer, you can’t cut and paste.
  • David Johnson
    July 21, 2005 at 3:27 am
    Also make sure your layer isn’t a locked “Background” layer…if it is, double click it to make it an editable layer. And, when you want to select a layer instead of a portion of it with one of the Marquee tools, Control-click it in the Layers list.
    No worries about the version…if these expensive pro applications aren’t your bread & butter, it’s not always wise to stay on the bleeding edge (the wallet & the brain from functionality problems & learning curves). Photoshop and similar apps are my bread & butter, but I still upgrade slowly to avoid the workflow hault that can come from initial release bugs, incompatabilites, etc.
