Activity Forums Avid Media Composer photoshop imports too short
  • photoshop imports too short
    Posted by Rick @ higher ground on November 14, 2006 at 6:54 pm
    I’m having a problem importing Photoshop CS v.8 files. I’ve scanned 22 CD covers and saved them as Photoshop documents. They are all around the same size, about 5 MBs. However when I import them into Xpress Pro 4.6.5 only 13 are at the duration I’ve specified, 30 seconds. The other nine end up as 2, 3, or 4 frames long. I tried changing their format to JPEG in order to reduce file size, but the same 9 come in short. I don’t know what the problem is. I’ve not had this happen before. Could there be a problem with the original scans? I’m perplexed.
    Rick M
    Higher Ground Productions
    Rick @ higher ground replied 19 years, 9 months ago 2 Members · 2 Replies
  • Satesh Ramjattan
    November 15, 2006 at 12:07 am
    Do you have import sequential files checked? If so, uncheck and see if that works.
  • Rick @ higher ground
    November 15, 2006 at 5:51 pm
    that was the fix!
    thanks,
    Rick M
