Activity Forums Apple Final Cut Pro Legacy photoshop file squeezed when imported into fcp7
  • photoshop file squeezed when imported into fcp7
    Posted by Ley Wilson on February 10, 2014 at 9:12 pm
    I was given a client .eps file with their logo that needs to cut into my FCP sequence. When I open in photoshop and save it to use in FCP it comes into FCP squeezed (as a sequence of course). All on a MAC.
    When my buddy does the same for me in PS but on a PC, it does NOT come in squeezed, but also not as a sequence (no separate layers).
    My sequence is square pixels and I make sure the PS file is saved that way as well. This is not a full screen graphic and has an odd pixel ratio because it just is what it is; 419 x 226. Of course I constrain proportions when I save it.
    As a test, if I drop it into AE and render it out, it works fine in FCP. Its not squeezed and does output with a matte, and keys no problem.
    I have been all over the internet, I see people talking about squeezed graphics but all the answers cover checking whether its NTSC 720 or 1080, or 19 whatever. but this is a size I cant use math to correct. (Yes, I know that made no sense)
    I have imported it 6 ways from Sunday to try and get it to work, but alas, it’s always stretched. I even brought it in tiny just in case it was squeezing to fit the screen, to no avail.
    Any ideas? Thanks!
    Ley Wilson replied 12 years, 6 months ago 2 Members · 5 Replies
  • Ley Wilson
    February 10, 2014 at 10:58 pm
    Thanks Dave,
    Yes I did. The logo even has a circle in it, so I could generate a circle (as a reference) then stretch this image’s circle over that till they match and know I had the right width. While also cracking up at FCP for not even being able to give me numbers for that stretching (x vs.y)
    But obviously that solves nothing, it is just a quick fix. And the anal person inside me wants to know how to do it right. Just seems some things shouldn’t be that hard.
    Especially since it comes from a PC .psd just fine
  • Ley Wilson
    February 10, 2014 at 11:06 pm
    Yeah I;ve messed with every setting I can think of; image size, canvas size, pixel aspect ratio, etc. Nada!
  • Nick Meyers
    February 11, 2014 at 8:42 am
    if your PSD has a transparent background, then FCP gets confused.
    it uses, or sees only the outermost pixels, and squishes the image to fit them.
    one trick is to put a single pixel in each of the four corners of your PSD.
    another might be to add a new layer of solid colour,
    then in FCP delete it.
    nick
  • Ley Wilson
    February 11, 2014 at 5:37 pm
    Thanks for the idea Nick. I tried it (adding a background layer) but couldnt get it to work. Then I even enlarged the canvas and sized the logo down, making the new background huge. But then when I imported it, the logo still came in squeezed just smaller.
    So far below is the best solution so far, given to me on the SFCutters forum by:
    “Marco Ramirez
    Film/Video Production & Post-Production Artist
    Are you bringing in the PS file or do you need to bring a logo in just for a simple overlay?
    My initial guess is FCP thinks it’s anamorphic; I would render as PNG, it’s great for logos and graphics, and it will also be much lighter to process. Make sure to turn off any unwanted background fills in your PS file before rendering, PNG will carry transparent pixels.
    Hope this helps…”
  • Ley Wilson
    February 13, 2014 at 8:16 pm
