Activity › Forums › Adobe Photoshop › photoshop cs5 problem with video layers and KEYFRAMES
  • photoshop cs5 problem with video layers and KEYFRAMES
    Posted by Esther Casas on October 18, 2011 at 4:52 pm
    Dear all!
    I am using photoshop cs5 (opened at 32bit mode as for video layers) to “paint” frames from a quick time movie I have exported with after effects (I used quick time format and i am exporting RGB and alpha channels).
    I have done this before and it worked with Photoshop cs4, but not anymore(?) and I have teh same problem with cs5. The problem is:
    I tried importing in two different ways:
    1) import video frames to layers, then i can work in timeline frame to frame as you do in after effects.
    2) open: I open a quicktime, and it shows you the video layer for it.
    the problem: the timeline shows my frames, but when you go through all of them is only showing you one single frame!!!???
    Thanks in advance!
    Esther.
    Esther Casas replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
