Activity Forums Adobe Photoshop Photoshop Acting Weird
  • Photoshop Acting Weird
    Posted by Bob Tanner on December 15, 2009 at 10:20 am
    I have a problem with Photoshop. When I apply an adjustment, such as curves, Photoshop applies curves for all the layers below it and just to the layer selected (this is not an adjustment layer). I have deleted the preferences and even reinstalled the whole CS4 Suite.
    I’m on a mac and I repaired the disk permissions using Disk Utility and I got this message, “Warning: SUID file “System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent” has been modified and will not be repaired.”
    Apple states that here,https://support.apple.com/kb/TS1448?viewlocale=en_US that I can safely ignore the message.
    I’m running OSX 10.6.2 and currently downloading a very large update from Adobe for the whole CS4 Suite, which hopefully will fix it…
    Any ideas,
    Zevie
    Bob Tanner replied 16 years, 9 months ago 2 Members · 2 Replies
  • Theo Van laar
    December 15, 2009 at 12:06 pm
    When you add an adjustment layer like CURVES, it will affect all layers below. But when you press on a PC Alt + plus the symbol for new adjustment layer (or press LAYER-NEW ADJUSTMENT LAYER from the menu) you will get a popup menu. Select in this popup menu the option USE PREVIOUS LAYER TO CREATE CLIPPING MASK, the adjustment layer will only work for the layer directly below.
    Theo
  • Bob Tanner
    December 15, 2009 at 1:01 pm
    Thanks a lot Theo, you really helped me 😀
