Activity › Forums › Adobe Illustrator › Photoshop 7 Duotone files import into Illustrator 9
  • Photoshop 7 Duotone files import into Illustrator 9
    Posted by Gawpertron on April 16, 2007 at 12:38 pm
    Hi
    I’ve created a duotone image in photoshop 7 and i can save it as a psd or eps to preserve the pantone colors i have picked.
    however when i try to import/place the file into an Illustrator 9 document it comes up with this error message:
    “The file “c:/yada yada.psd” is in a format which can not be placed”
    And i can’t even import an eps file.
    Has anyone ever had a similar problem? and does anyone know of a way around this. It is important to keep the pantone information.
    Is there a way in illustrator 9 to place a grayscale psd or similar file and then assign the pantone colours within illustrator 9 to that image object.
    cheers
    Adam
    Mike Gondek replied 19 years, 5 months ago 2 Members · 1 Reply
  • Mike Gondek
    April 16, 2007 at 2:00 pm
    Ilustrator CS2 is only able to place the .eps, since it cannot place a .psd when it is duotone.
    Look into updating your software, Illustrator 9 was not one of my least favorite as it crashed often or had printing problems with transparency.
    You should be able to place a grayscale and colroize it. Test to make sure it seperates accurately, as it has been a while since I colorized a tif.
