Activity Forums Apple Final Cut Pro Legacy Photos and still stretching when rendered, 1080i HDV
  • Photos and still stretching when rendered, 1080i HDV
    Posted by Daniel Carbone on April 13, 2009 at 5:42 pm
    Hey gang,
    I am currently cutting an hour-long doc for South African television. The footage and sequence is all 1080i (1440×1080, rectangular pixels i believe) HDV. I have edited countless projects in DVCProHD, but have never really worked with HDV before and I was wondering if anyone might be able to shed some light on an issue I am having.
    When importing .tiff files and dropping them into the timeline, they act normally. I can blow them up, crop them, color correct, etc and they always display fine. However, once I render them (the dialog box reads “Conforming HDV video” rather than the normal “writing video”) many (but not all) of them end up being extremely distorted, often much wider than they should be. If I then place text on them or alter them in some way, they go unrendered again and display correctly.
    Any ideas? I have a feeling its something simply I am forgetting to do, but Im having trouble narrowing it down since its not every .tiff that has issues. Does it have to do with square vs rectangular pixels? Is there a photoshop step I am missing before importing?
    Thanks very much in advance,
    Daniel
    Chris Poisson replied 17 years, 5 months ago 3 Members · 4 Replies
  • Chris Poisson
    April 13, 2009 at 5:53 pm
    Daniel,
    Change your compressor to ProRes and re render. Working in HDV is horses__t.
    Better to capture to ProRes to begin with.
    Have a wonderful day.
  • Walter Biscardi
    April 13, 2009 at 6:05 pm
    [Chris Poisson] “Working in HDV is horses__t. “
    That’s the best description of working with that codec I’ve ever seen.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Daniel Carbone
    April 14, 2009 at 4:06 am
    Hey Chris,
    Im beginning to share your opinion on HDV. Can you be more detailed in what I should re-render to? Should I simply change the codec and leave all other parameters the same? (field order, aspect ratio (1440×1080, etc)
    thanks for your help.
    Dan
  • Chris Poisson
    April 14, 2009 at 9:11 pm
    Dan,
    Just go into your sequence settings and change the compressor to 8 bit or ProRes, depending on your system. You will have to re-render but everything will be beautiful, including keys and color correction.
    But in the future, if you have FCP 6.0.2 you can just capture everything to ProRes and be done with it.
