Activity › Forums › VEGAS Pro › photos
  • Mike Kujbida
    May 5, 2009 at 4:56 pm
    Here’s two different ways to do this.
    #1.
    Split the track (use the S key), move the right side over to the left to make room, drop the image on the timeline, adjust the length and slide the right clip back.
    Overlap (aka fade/dissolve) if desired.
    If you wnat a different transistion, choose one and drop it on top of the dissolve.
    #2.
    Ceate a new video track above the existing one and drop an image on the timeline at the desired location.
    Doing it this way keeps the existing audio track(s) intact.
    Once again, adjust the length and fade in/out as desired.
