Activity › Forums › Adobe After Effects › PhotoJpeg footage in CS5 is all blue and magenta
  • PhotoJpeg footage in CS5 is all blue and magenta
    Posted by Corrado Carlevaro on September 17, 2010 at 10:48 am
    I just updated to After Effects CS5 (10.0.1.19) and when I import stock footage (from VideoCopilot, DigitalJuice etc.) which is .mov and PhotoJpeg, this is displayed in blue and magenta colors.
    I hadn’t this issue with CS4.
    Any suggestions?
    Corrado Carlevaro
    Walter Soyka replied 15 years, 8 months ago 7 Members · 16 Replies
  • 16 Replies
  • Walter Soyka
    September 17, 2010 at 1:32 pm
    [Corrado Carlevaro] “I just updated to After Effects CS5 (10.0.1.19) and when I import stock footage (from VideoCopilot, DigitalJuice etc.) which is .mov and PhotoJpeg, this is displayed in blue and magenta colors.”
    There was a similar problem with ProRes 422 media, and the cause was a conflict with AJA’s codec.
    If you happen to have an AJA card installed, try disabling its video preview, switching color depth to 16 or 32 bpc, or updating or uninstalling the AJA drivers.
    Walter Soyka
  • Corrado Carlevaro
    September 17, 2010 at 2:40 pm
    Thank you for your (very) swift reply, and yes, I have an AJA card. I tried to disable video preview and to change color depth (inside After Effects, am I wrong?) but with no results. I’ll reinstall or update drivers as soon as I can.
    Thank you again
    Corrado Carlevaro
  • Todd Kopriva
    September 17, 2010 at 6:11 pm
    We’re communicating with AJA about this now. The last I heard (earlier this week), they were intending to release new software to fix this issue. I’ll check and see when that is expected to be available.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Daniel Ramirez
    September 17, 2010 at 6:39 pm
    If you have AJA hardware installed, it’s possible that Photo-JPEG and ProRes footage(8bpc only) will be corrupted(looks pink and blue) in the latest update of AE. I’ve verified this problem with the Kona3 on two Mac machines.
    As far as I know, there are no workarounds at this moment. AJA is aware of this issue and I expect a fix in the next public driver update.
    Unfortunately; I am unable to get a time estimate on when that driver will be available. If I get new information, or the driver becomes available; I’ll make sure to reply to this thread.
    Dan Ramirez
    After Effects
    QA Engineer
  • Corrado Carlevaro
    September 20, 2010 at 11:37 am
    Thank you everybody. That’s a forum!
    Corrado Carlevaro
  • Walter Soyka
    October 6, 2010 at 5:14 pm
    I just ran into this myself with some PhotoJPEG footage.
    I have worked around it. I completely uninstalled my AJA 8.0 drivers, rebooted, installed old AJA 7.5.1 NDD drivers, rebooted, and now my PhotoJPEG footage looks normal again in AE CS5.
    I’ve just done this a couple minutes ago, and I will report back if I run across any other problems.
    Todd or Daniel, any news on updated AJA drivers?
    Walter Soyka
  • Walter Soyka
    October 6, 2010 at 5:27 pm
    [Walter Soyka] “I’ve just done this a couple minutes ago, and I will report back if I run across any other problems.”
    Never mind. The PhotoJPEG footage only sporadically works, and is sporadically pink and blue.
    I’m off to transcode to ProRes.
    Walter Soyka
  • Todd Kopriva
    October 6, 2010 at 10:01 pm
    We’ve tested a driver from AJA that fixes the problem. Now it’s up to AJA to complete their testing and production. We don’t know (and couldn’t comment anyway) about AJA’s schedule.
  • Walter Soyka
    October 7, 2010 at 4:56 pm
    Thanks, Todd.
    Walter Soyka
  • Emile Gorissen
    December 9, 2010 at 4:22 pm
    Maybe a usefull workaround.
    Start your after effects with video preview off.
    Your footage should be ok now.
    Then turn the video preview on.
    All will be ok.
    You heve to do this each time when you restart after effects.
    So put you video preview off before closing your after effects session.
    Emile
