Activity Forums VEGAS Pro Photo duration decrease over time. Workflow/script?
  • Photo duration decrease over time. Workflow/script?
    Posted by Paul Tanner on July 12, 2011 at 7:50 pm
    Hi Guys, I have this project in mind where I want to use a couple hundred images (all related subject) to start out about 2 seconds duration and quickly, but uniformly, decrease in duration to final shots about “blink of an eye”. The track length is about 18-19 seconds. How would I go about this to have a consistent (x minus y) workflow that isn’t tediously shortening the length of each image one by one? It’d be awesome if there was a script for this. I’m trying to build a rise or adrenaline rush out the climatic end. Thanks!!!
    Using Sony Vegas Pro 10
    Paul Tanner replied 15 years, 1 month ago 4 Members · 4 Replies
  • Steve Rhoden
    July 12, 2011 at 9:54 pm
    Both Vegas Production Assistant and Vasst UltimateS has the feature
    you are looking for…For you to manipulate and adjust to fit your
    climatic buildup.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Hallgeir Gjesdal
    July 12, 2011 at 11:24 pm
    I would start with an empty project, then drag all of the pictures to timeline at ones (Still-image lenght is 5 sec by default I think, it can be changed in Preferences).
    Be sure “Automatic Crossfades (CTRL-SHIFT-X)” is not active. This will make a slideshow. Save project as slide.veg.. Now close this project.
    Start a new project, drag’n drop this generated slide.veg onto timeline. Right-click event and insert velosity envelope. Now you can manipulate speed and CTRL-drag event end to meet your needs.
    Hopefully this will help you, but maybe there is another and simplified way to do this.
    Hallgeir
  • Aleksey Tarasov
    July 13, 2011 at 4:31 am
    You can open all images in the sequence as a single entry in the Project Media window, with the desired frame rate (File > Import > Media, select Open still image sequence option, images must be named like image001.jpg, image002.jpg etc.). Then use Velocity envelope for consistent increasing the speed. Voila!
  • Paul Tanner
    July 13, 2011 at 9:26 am
    Thanks gentlemen, great options and I liked how all three are different workflows for flexible options. Seeing as you guys may have done this, what is the shortest duration most professionals use for this type of effect? On a 30fps timeline… how little of frames are we talking for the last set of “blink of an eye” images? I hope I worded that correct.
