Activity Forums Adobe Photoshop Phothsop runs slow using curves on masks
  • Phothsop runs slow using curves on masks
    Posted by Mike Gondek on June 11, 2008 at 4:50 pm
    I have a color correction layers with a mask, when I try to run levels or curves Photoshop gets real slow. This happens on most any file and sometimes it works fat and then gets in a rut and slows down to to taking 5 minutes after pulling a slider.
    I have tried:
    resetting prefs
    restarting machine
    setting my histogram and cache levels to max performance
    disconnecting from network
    purging cache
    I am on a G5 2Ghx 3GB Mac OS 10.4.8
    PSD version 10.0.1
    The current image is only 240 Mb
    Mike Gondek replied 18 years, 2 months ago 1 Member · 2 Replies
  • Mike Gondek
    June 11, 2008 at 5:03 pm
    Update: It is slow on masks, not on colro layers. If I turn color management to off the problem is solved,but I need color management.
  • Mike Gondek
    June 11, 2008 at 10:13 pm
    Problem fixed it was a bad color profile we ae using.
