Activity › Forums › Apple Final Cut Pro Legacy › Phantom Volumes Created by Motion
  • Phantom Volumes Created by Motion
    Posted by Keith Golinski on March 24, 2008 at 8:33 pm
    I had an interesting issue occur that I didn’t realize was happening until I ran out of startup hard drive space. I set my autosave vault and my retiming cache preferences to an external hard drive and set it to a specific folder. I thought that was all I had to do to make sure the files were being rendered out to them but for some reason I have a new folder on my startup drive that is listed as Autosave Vault and in it I found several files that I thought were going to the volume I had already specified. When I went to the internal hard drive to find them however the volume is not listed but is taking up real hard drive space. Most of the file space is taken up with .mv files but they are impossible to locate in a spot outside of the Motion Prefernces window where they can’t be deleted. Short of dumping my entire Start-up drive and starting fresh has anyone else run into this issue or have you even realized this is happening. I hadn’t realized it until today when I ran out of drive space.
    Keith Golinski replied 18 years, 6 months ago 1 Member · 2 Replies
  • Keith Golinski
    March 25, 2008 at 2:07 pm
    So I’m still trying to find the files that are lost on my start-up disc. I found out that the cache retiming files from motion were located in the motion documents folder which I deleted thinking that would solve the problem. It didn’t. So now I’m unable to access the cache files which are taking up about 40 gigs of space on my startup disc. Looks like a fresh install will be the only help at this point.
  • Keith Golinski
    March 25, 2008 at 3:26 pm
    I fixed it!
    I ended up using the terminal app. in the utilities folder and found the volumes by typing in open /volumes/
    the phantom volume appeared in the finder window and I was able to trash it from there opening up 35 gigs of start-up disk space.
    so the moral to the story pay close attention to the cache files that motion puts in default folders. You could be losing valuable start-up disk space.
    Keith
    fulvew.com
