Activity Forums Maxon Cinema 4D PFTrack gives me a Camera in C4d But not a moving object?
  • PFTrack gives me a Camera in C4d But not a moving object?
    Posted by Jeremy Grubaugh on December 21, 2008 at 11:24 pm
    I am wondering if there is a work around for the issue I am having so hold with me as i try to explain it. So i am trying to learn PFTrack and use it in concert with Cinema 4D. What I am trying to do is track a Women’s face so that she can throw her hair around or other dynamics that may be attached to her head. The problem is PFTrack provides me with a camera instead of the moving object I tracked. So while when looking through the camera (In C4D) the head appears to be moving it is not (See linked file). So if i were to apply objects that would move based on the heads movement they would simply remain still.
    Is there a way around this. Is there a way to turn a cameras movement into an objects movement so that the camera remains still while the objects inherit all the movement?
    My file
    https://www.fluidresolution.com/FaceShake.zip
    Test composite
    https://vimeo.com/2594664
    – JG
    I didn’t like cheeseburger alley cats near me!
    Jeremy Grubaugh replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
