Activity › Forums › Adobe After Effects › Perspective and Glow on Text
  • Perspective and Glow on Text
    Posted by Ashley Ripka on September 28, 2017 at 2:00 pm
    I am trying to create this effect in AE and I feel like it should be rather easy, but I’m finding it really difficult.
    It doesn’t have to look incredibly realistic, but I am looking to make this believable.
    I am trying to create a short animation of text glowing on this pumpkin. I can’t seem to find a decent perspective control. I’ve used CC Cylinder, but it’s not quite there. I also am not crazy that it throws a light on there. Is there another preset, or another route where I can wrap the text around the pumpkin?
    I also want to add a glow to make it flicker a bit, but when I add the glow effect, it does nothing. I haven’t used this effect in years, and I feel like they maybe changed it. I tried create the text in photoshop with bevels and shadows to make it look like it was carved into the pumpkin, but when I import it into AE and apply the glow, it doesn’t work. It’s pretty much just applying the effect to the bevel. I even tried creating a precomp and adding the glow to the precomp and it wont do anything.
    Any help would be much appreciated!
    Angie Taylor replied 9 years ago 2 Members · 2 Replies
  • Angie Taylor
    September 29, 2017 at 12:14 am
    You can create a curve by adding position and Rotation text animators. Add per character 3D tonit and then adjust the settings for Z Position and Y Rotation. To create a smooth curved, go into the Range Selector> Advanced Options and change the setting from
    Square to Round Or Smooth.
    Once you s done this you can use layer styles in AE to add bevels, shadows and a glow.
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Angie Taylor
    September 29, 2017 at 12:17 am
    And, also, try adding a displacement map to the Text layer. In the DM
    Effect, choose the pumpkin as the displacement layer and tweak the horizontal
    And vertical settings to taste. The Red channel will probably work well. This will
    Appear to Distort the text Along the surface of the pumpkin.
    cheers,
    Angie
