Activity Forums Maxon Cinema 4D Perpendicular planes and modeling.
  • Perpendicular planes and modeling.
    Posted by Nicolas1 on November 12, 2006 at 11:36 am
    I’m a complete newb and can’t seem to find a method to create 2 perpendicular planes in order to use hypernurbs for modeling.
    Could someone please direct me to a tutorial?
    TIA
    Nicolas
    Arndt Von koenigsmarck replied 19 years, 10 months ago 2 Members · 1 Reply
  • Arndt Von koenigsmarck
    November 12, 2006 at 8:27 pm
    When using the plane primitive you can find an axis parameter within the attribute manager.
    Choose -Z for the plane that should be in front view and +X or -X for the plane that should be visible in the side view. Depends on the kind of templates you plan to use.
    If this is still not working for you. create a cube primitive and activate the separate faces option before converting this cube to a polygon object. This gives you six square polygons to choose from which are all perpendicular to the neighbouring polygons.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
