Activity › Forums › Apple Final Cut Pro Legacy › Performing a swap edit whilst keeping other tracks in sync
  • Performing a swap edit whilst keeping other tracks in sync
    Posted by Tom Hannibal on May 15, 2009 at 3:48 pm
    I’m going a bit crazy trying to figure out how to do a swap edit in my timeline without knocking my other tracks out of sync.
    In Avid I could just turn Sync Lock on and go into Segment Mode and do it no problem, but can’t find out how to do the same thing in FCP (v5)
    Tom
    Karlis Kay replied 15 years, 4 months ago 4 Members · 5 Replies
  • Dennis Leppell
    May 15, 2009 at 5:24 pm
    lock the tracks you don’t need and drop your clip into place. F4 will lock all video tracks, f5 all audio. Clicking the little locks to the left of the tracks will lock/unlock just that track.
    f9 will insert the clip from your viewer to your timeline at the timeline in point or the playhead, in that order of preference, using the clip’s in/out points. This will push all clips behind it down the line. and locked tracks will not be affected.
    f10 will overwrite the clip onto the timeline, without pushing anything down the line. all locked tracks will be unaffected.
    f11 will replace the clip on the timeline with the clip in the viewer, using the viewer’s in point, and the timeline clip’s out point for correct length.
    For both those functions, if you have your audio tracks locked the existing audio will not be affected (and vice versa for video.
    If you are dragging clips from the bin/viewer to the timeline, if the arrow is pointing right, it will insert. If the arrow is pointing down it will overwrite. depending on where the cursor is in relation to the height of the track will cause the switch between the two functions. you can cycle through the different track heights by clicking on the little bar graph in the bottom left corner of the timeline. (I use the g button to do this, but I think I had to map that myself).
  • Tom Hannibal
    May 18, 2009 at 9:58 am
    I’ve already got my clips in my sequence, I just want to rejig the order of them. If I lock the tracks then surely it’s not going to preserve my sync on V2 etc?
    Tom
  • Tom Wolsky
    May 18, 2009 at 10:04 am
    Try using the ripple cut function Shift-X with paste insert Shift-V.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Tom Hannibal
    May 18, 2009 at 10:10 am
    Brilliant, that worked, thanks!
    Seems a bit strange that there’s not a ‘drag and drop’ way to do it though…
    Tom
  • Karlis Kay
    June 3, 2011 at 9:48 am
    Another way is to select the clip you want to swap, hold down the option key and drag the selected clip over to any edit point you want to insert the clip into. You should see a little curved down arrow. Once the clip looks like it’s going to snap into position, release the clip – it should lock in leaving all other clips in sequence.
    Actually – that’s a pretty poor explanation. This video does a much better job…
    https://vimeo.com/7853624
    Hope that helps
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
